Ana içeriğe geç
Swann Doorphone Video Intercom Microphone Replacement
Neye ihtiyacın var
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: adım 1, 3 resimden 1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: adım 1, 3 resimden 2. Swann Doorphone Video Intercom Microphone Replacement, Microphone: adım 1, 3 resimden 3.
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: adım 2, 2 resimden 1. Swann Doorphone Video Intercom Microphone Replacement: adım 2, 2 resimden 2.
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: adım 3, 3 resimden 1. Swann Doorphone Video Intercom Microphone Replacement: adım 3, 3 resimden 2. Swann Doorphone Video Intercom Microphone Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: adım 4, 3 resimden 1. Swann Doorphone Video Intercom Microphone Replacement: adım 4, 3 resimden 2. Swann Doorphone Video Intercom Microphone Replacement: adım 4, 3 resimden 3.
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Sonuç
Emily Stenke
555 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 392
