Ana içeriğe geç
Swann Doorphone Video Intercom Wire Replacement
Neye ihtiyacın var
  1. Swann Doorphone Video Intercom Wire Replacement, Wire: adım 1, 3 resimden 1. Swann Doorphone Video Intercom Wire Replacement, Wire: adım 1, 3 resimden 2. Swann Doorphone Video Intercom Wire Replacement, Wire: adım 1, 3 resimden 3.
    • Flip the monitor of the Swann Doorphone over so that the underside is facing up.
    • Grip the sides of the black rectangular frame where they extend outwards and pull down.
    • After pulling down, pull the frame towards you to remove it from the monitor.
  2. Swann Doorphone Video Intercom Wire Replacement: adım 2, 3 resimden 1. Swann Doorphone Video Intercom Wire Replacement: adım 2, 3 resimden 2. Swann Doorphone Video Intercom Wire Replacement: adım 2, 3 resimden 3.
    • Using the JIS #0 screwdriver, unscrew the 2 mm screw in terminal 1 with the blue wire underneath.
    • Pull the blue wire out from beneath the metal plate.
    • Be careful when removing the screw from terminal 1, the metal plate behind the screw is not connected and may fall off.
  3. Swann Doorphone Video Intercom Wire Replacement: adım 3, 3 resimden 1. Swann Doorphone Video Intercom Wire Replacement: adım 3, 3 resimden 2. Swann Doorphone Video Intercom Wire Replacement: adım 3, 3 resimden 3.
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  4. Swann Doorphone Video Intercom Wire Replacement: adım 4, 3 resimden 1. Swann Doorphone Video Intercom Wire Replacement: adım 4, 3 resimden 2. Swann Doorphone Video Intercom Wire Replacement: adım 4, 3 resimden 3.
    • With the back cover of the outdoor camera off, press the first gray square button with blue wire down.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
    • In this guide, we are using the blue wire in terminal 1 for the audio. As a recommendation; * Use the blue wire in terminal 1 for the audio wire. * Use the brown wire in terminal 2 for the ground wire. * Use the green wire in terminal 3 for the video wire. * Use the black wire in terminal 4 for the power wire.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emily Stenke
555 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 22
Her zaman: 1,724
