Ana içeriğe geç
Sylvania SDVD9004 Motherboard Replacement
Neye ihtiyacın var
  1. Sylvania SDVD9004 Motherboard Replacement, Back cover: adım 1, 1 resimden 1.
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Motherboard Replacement: adım 2, 2 resimden 1. Sylvania SDVD9004 Motherboard Replacement: adım 2, 2 resimden 2.
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Motherboard Replacement: adım 3, 1 resimden 1.
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Motherboard Replacement, CD Drive: adım 4, 3 resimden 1. Sylvania SDVD9004 Motherboard Replacement, CD Drive: adım 4, 3 resimden 2. Sylvania SDVD9004 Motherboard Replacement, CD Drive: adım 4, 3 resimden 3.
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  5. Sylvania SDVD9004 Motherboard Replacement: adım 5, 1 resimden 1.
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  6. Sylvania SDVD9004 Motherboard Replacement: adım 6, 1 resimden 1.
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
  7. Sylvania SDVD9004 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Sylvania SDVD9004 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Sylvania SDVD9004 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Remove Ribbon from Rear Panel
  8. Sylvania SDVD9004 Motherboard Replacement: adım 8, 1 resimden 1.
    • Anchor screw removal
    • Use Philip's head screwdriver
    • Place head of driver into screw on mother board.
    • Remove all four screws
  9. Sylvania SDVD9004 Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift motherboard to expose battery
Sonuç
Sarah Henry
417 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-10, Williams Fall 2016 Baylor, Team 5-10, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G10
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 382
