Ana içeriğe geç
Sylvania SDVD9004 Screen Replacement
Neye ihtiyacın var
  1. Sylvania SDVD9004 Screen Replacement, Back cover: adım 1, 1 resimden 1.
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Screen Replacement: adım 2, 2 resimden 1. Sylvania SDVD9004 Screen Replacement: adım 2, 2 resimden 2.
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Screen Replacement: adım 3, 1 resimden 1.
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Screen Replacement, Screen: adım 4, 3 resimden 1. Sylvania SDVD9004 Screen Replacement, Screen: adım 4, 3 resimden 2. Sylvania SDVD9004 Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Disconnect ribbon
    • Rotate screwdriver to peel sticker from ribbon.
    • Place spudger head behind gray tabs on port.
    • Press outward to disengage tab.
    • Repeat on other side.
    • Slide out ribbon.
  5. Sylvania SDVD9004 Screen Replacement: adım 5, 2 resimden 1. Sylvania SDVD9004 Screen Replacement: adım 5, 2 resimden 2.
    • Using Philips head screwdriver, remove the two 7 mm screws.
    • Slide off top panel.
Sonuç
Sarah Henry
417 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-10, Williams Fall 2016 Baylor, Team 5-10, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G10
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 623
