Giriş
Replace the the gyro on your Syma S107 so that it stops self destructing.
Neye ihtiyacın var
Remove the gyro carriage by removing the following screws:
Two 5.6mm Phillips #0.
Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
7 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Cheers thanks too this page I fixed problem great , Martin
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Now it flies in an oval pattern wat am I doing wrong?
