Giriş
Replace the the gyro on your Syma S107 so that it stops self destructing.
Neye ihtiyacın var
Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
Remove the gyro carriage by removing the following screws:
Two 5.6mm Phillips #0.
Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
7 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Cheers thanks too this page I fixed problem great , Martin
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
Now it flies in an oval pattern wat am I doing wrong?
