Ana içeriğe geç
Synology DS1019+ - a complete disassembly in rules
Neye ihtiyacın var
  1. Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: adım 1, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: adım 1, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Presentation: the different faces of the case: adım 1, 3 resimden 3.
    • Here are the different interesting faces of the case: front (bay disks), rear (connectors and fans), below (2 hatches SSD).
    • This NAS DS1019+ is equipped with 8 GB of memory, an INTEL Celeron J3455 64-bit Quad processor, five bays for SATA drives.
    • FRONT : disk cage lock / REAR : Kensington security incision (K-lock)
    • 2 USB 3 ports (1 in front and 1 behind)
    • 2 x RJ45 Gb ports.
    • FRONT : 1 port for power supply
    • BELOW : 2 M.2 NVMe 2280 ports (disk cache)
    • REAR : 1 eSATA port
  2. Synology DS1019+ - a complete disassembly in rules, Unlock the disk media: adım 2, 1 resimden 1.
    • Before teardown, unlock the disk media with the key.
  3. Synology DS1019+ - a complete disassembly in rules, Removes disks from the bay: adım 3, 2 resimden 1. Synology DS1019+ - a complete disassembly in rules, Removes disks from the bay: adım 3, 2 resimden 2.
    • Since the media are unlocked, remove each disk media.
  4. Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: adım 4, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: adım 4, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Backplane and memory slot access: adım 4, 3 resimden 3.
    • This is a significant innovation, the memory is now directly accessible and without disassembly of the housing, for the original bar as for the extension port.
    • backplane with 5 SATA connectors
    • 2 memory slots
  5. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 1/2: adım 5, 1 resimden 1.
    • Remove the 2 screws on the back of the case at the top and bottom (not the one above the USB port)
  6. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: adım 6, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: adım 6, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Housing: hood removal 2/2: adım 6, 3 resimden 3.
    • Slide the cover forward, then slide it out (here, to the left).
  7. Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: adım 7, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: adım 7, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Internal parts: presentation: adım 7, 3 resimden 3.
    • in red: SSD M.2 expansion card 2280
    • in yellow: USB 3 port
    • in orange: internal connectors of the 2 fans
    • in green: 2 slots of RAM
    • in blue: SATA III backplane (5 hard drive bays)
    • in pink: fixing the fans on the chassis
    • 3-PIN connectors of the fans
  8. Synology DS1019+ - a complete disassembly in rules, USB 3 port removal: adım 8, 2 resimden 1. Synology DS1019+ - a complete disassembly in rules, USB 3 port removal: adım 8, 2 resimden 2.
    • Insérez ici votre traduction
    • Remove the 2 screws from the holding plate of the USB connector 3 and on the rear side.
    • Then remove the USB3 metal plate.
    • Removal of the SSD M2 board is not necessary for motherboard disassembly.
    • Do not remove the USB connector 3 on the motherboard, it is glued. It does not interfere with disassembly!
  9. Synology DS1019+ - a complete disassembly in rules, Removing fan clips: adım 9, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Removing fan clips: adım 9, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Removing fan clips: adım 9, 3 resimden 3.
    • Remove the screws from the two shims to secure the disc cage and the two fans.
    • These plastic spacers are keyed
  10. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: adım 10, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: adım 10, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 1/2: adım 10, 3 resimden 3.
    • 4 Phillips screws must be removed from two side.
    • Remove the fans's 3-PIN power cable
  11. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 2/2: adım 11, 2 resimden 1. Synology DS1019+ - a complete disassembly in rules, Remove motherboard from the hood 2/2: adım 11, 2 resimden 2.
    • Here, the motherboard is still secure to the disk cage.
    • Remove the motherboard from the case paying attention to the USB 3 connector on the front and the power button. To do this, move the front panel a little and lift the motherboard upwards (outside).
    • Take care.
  12. Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: adım 12, 3 resimden 1. Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: adım 12, 3 resimden 2. Synology DS1019+ - a complete disassembly in rules, Unsecure the motherboard from the metal cover: adım 12, 3 resimden 3.
    • Once the motherboard is out, unscrew the 4 screws of the metal protective cover (metal plate).
  13. Synology DS1019+ - a complete disassembly in rules, Motherboard: processor side: adım 13, 1 resimden 1.
    • Motherboard processor side
    • INTEL Celeron J3455 / 64-bit / Quad core 1.5 burst up to 2.3 GHz
    • Memory battery
    • Internal beep
    • USB 3 port
    • Power button
    • Flash memory
  14. Synology DS1019+ - a complete disassembly in rules, Motherboard: memory side: adım 14, 1 resimden 1.
    • Memory side of the motherboard (pre-equipped with 8 GB of RAM)
    • NVMe M.2 SSD expansion card connector
    • Connector (PCIe ??) for SATA disk expansion card
    • Fan connector (x2)
    • Power connector
    • RJ45 LAN Connector x2
    • eSATA connector
    • 2 x 4GB DDR3L 1866 RAM Memory Stick
Sonuç
To reassemble your device, follow the instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Sébastien
4.204 İtibar
6 adet Kılavuz yazıldı
Ekip
AEM (ANIMA EX MACHINA) AEM (ANIMA EX MACHINA) üyesi
Business
1 Üye
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 98
Her zaman: 3,857
