Ana içeriğe geç
Syntus ST150 Ultrasonic Plate Replacement
Neye ihtiyacın var
  1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: adım 1, 1 resimden 1.
    • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
    • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
  2. Syntus ST150 Ultrasonic Plate Replacement: adım 2, 2 resimden 1. Syntus ST150 Ultrasonic Plate Replacement: adım 2, 2 resimden 2.
    • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
  3. Syntus ST150 Ultrasonic Plate Replacement: adım 3, 3 resimden 1. Syntus ST150 Ultrasonic Plate Replacement: adım 3, 3 resimden 2. Syntus ST150 Ultrasonic Plate Replacement: adım 3, 3 resimden 3.
    • Lift the water tank while holding the base of the diffuser.
    • Disconnect the three cables form the board.
    • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
  4. Syntus ST150 Ultrasonic Plate Replacement: adım 4, 3 resimden 1. Syntus ST150 Ultrasonic Plate Replacement: adım 4, 3 resimden 2. Syntus ST150 Ultrasonic Plate Replacement: adım 4, 3 resimden 3.
    • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
  5. Syntus ST150 Ultrasonic Plate Replacement: adım 5, 3 resimden 1. Syntus ST150 Ultrasonic Plate Replacement: adım 5, 3 resimden 2. Syntus ST150 Ultrasonic Plate Replacement: adım 5, 3 resimden 3.
    • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
    • Remove the cover to expose the ultrasonic sensor.
  6. Syntus ST150 Ultrasonic Plate Replacement: adım 6, 3 resimden 1. Syntus ST150 Ultrasonic Plate Replacement: adım 6, 3 resimden 2. Syntus ST150 Ultrasonic Plate Replacement: adım 6, 3 resimden 3.
    • Detach the ultrasonic sensor from the water tank.
    • Detach the ultrasonic sensor connector from the board.
  7. Syntus ST150 Ultrasonic Plate Replacement: adım 7, 1 resimden 1.
    • Remove the rubber cover from the ultrasonic plate.
  8. Syntus ST150 Ultrasonic Plate Replacement: adım 8, 1 resimden 1.
    • Now you can replace the ultrasonic plate of your diffuser.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 555
