Ana içeriğe geç
T-Mobile Huawei Prism U8651T LCD Replacement
Neye ihtiyacın var
  1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: adım 1, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: adım 1, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: adım 1, 3 resimden 3.
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: adım 2, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: adım 2, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: adım 3, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: adım 3, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: adım 3, 3 resimden 3.
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: adım 4, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: adım 4, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: adım 4, 3 resimden 3.
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: adım 5, 2 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: adım 5, 2 resimden 2.
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: adım 6, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: adım 6, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: adım 6, 3 resimden 3.
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: adım 7, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: adım 7, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: adım 7, 3 resimden 3.
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: adım 8, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: adım 8, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: adım 8, 3 resimden 3.
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: adım 9, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: adım 9, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: adım 9, 3 resimden 3.
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: adım 10, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: adım 10, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: adım 10, 3 resimden 3.
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: adım 11, 3 resimden 1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: adım 11, 3 resimden 2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: adım 11, 3 resimden 3.
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dillon
578 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 999
