Giriş
This guide is useful if the SD card in the device is not working or properly installed.
Aletler
Hiçbir alete gerek yok.
Parçalar
Hiçbir parçaya gerek yok.
  1. To remove the battery cover, first turn the phone so that the keypad is face down. While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover. Slide the battery cover toward the bottom of the phone to remove.
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. To remove the battery, first grab it using a finger on either side. Pull the battery upward, while securing the phone with your other hand.
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Locate the slot for the SD card on the back of the phone. Insert the SD card so that the copper connectors on the card line up with the connectors on the phone (no card pictured).
    • Locate the slot for the SD card on the back of the phone. Insert the SD card so that the copper connectors on the card line up with the connectors on the phone (no card pictured).
  5. Secure the SD card in place by sliding the silver tab over it (SD card not pictured).
    • Secure the SD card in place by sliding the silver tab over it (SD card not pictured).
Sonuç
Colin Horgan
32 İtibar
2 adet Kılavuz yazıldı
Takım
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 210
