Ana içeriğe geç
TCA PRC 152A Disassembly
Neye ihtiyacın var
  1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: adım 1, 1 resimden 1.
    • Remove antenna and battery before dissasembly
    • Prepare the tools before starting We'll start with the radio and then the accessories...
  2. TCA PRC 152A Disassembly, Removing the backpannel: adım 2, 3 resimden 1. TCA PRC 152A Disassembly, Removing the backpannel: adım 2, 3 resimden 2. TCA PRC 152A Disassembly, Removing the backpannel: adım 2, 3 resimden 3.
    • Remove 4 screws on the backpannel
    • Phillips PH3
    • The small retention piece is held by the screw. Be careful not to lose the spring
  3. TCA PRC 152A Disassembly, Removing the backpanel: adım 3, 2 resimden 1. TCA PRC 152A Disassembly, Removing the backpanel: adım 3, 2 resimden 2.
    • Carefully open the rear panel with the opener's plastic tool.
    • You can see the connection map of the different terminals.
    • GPS option (Does not work)
    • PTT and config button socket
    • U283 6PIN connector
    • ON/OFF/Volume knob
    • Side connector (Does not work)
  4. TCA PRC 152A Disassembly, Removing frontpannel: adım 4, 3 resimden 1. TCA PRC 152A Disassembly, Removing frontpannel: adım 4, 3 resimden 2. TCA PRC 152A Disassembly, Removing frontpannel: adım 4, 3 resimden 3.
    • Carefully open the front panel with the opener's plastic tool.
    • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
    • Speaker FCE 16Ohm 1Watt.
    • Beware of silicone for the sealing of the elements.
  5. TCA PRC 152A Disassembly, Frontpannel microphone removal: adım 5, 3 resimden 1. TCA PRC 152A Disassembly, Frontpannel microphone removal: adım 5, 3 resimden 2. TCA PRC 152A Disassembly, Frontpannel microphone removal: adım 5, 3 resimden 3.
    • Remove 1 screw
    • Phillips PH1
    • Carefully remove withe the plastic tool
  6. TCA PRC 152A Disassembly, Display and keyboard front card: adım 6, 3 resimden 1. TCA PRC 152A Disassembly, Display and keyboard front card: adım 6, 3 resimden 2. TCA PRC 152A Disassembly, Display and keyboard front card: adım 6, 3 resimden 3.
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the flat connector
    • Use caution when you remove the flat connector
  7. TCA PRC 152A Disassembly, Display and keyboard front card: adım 7, 2 resimden 1. TCA PRC 152A Disassembly, Display and keyboard front card: adım 7, 2 resimden 2.
    • Place the electronics elements on ESD bags
  8. TCA PRC 152A Disassembly, Peripheral back card: adım 8, 3 resimden 1. TCA PRC 152A Disassembly, Peripheral back card: adım 8, 3 resimden 2. TCA PRC 152A Disassembly, Peripheral back card: adım 8, 3 resimden 3.
    • Disconnect 2 JSP connectors and 2 flat connector
    • Remove 4 screws
    • Phillips PH2
    • Carefully disconect the connectors and the board
  9. TCA PRC 152A Disassembly, Mainboard removal: adım 9, 3 resimden 1. TCA PRC 152A Disassembly, Mainboard removal: adım 9, 3 resimden 2. TCA PRC 152A Disassembly, Mainboard removal: adım 9, 3 resimden 3.
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the antenna connector
    • Carefully removing the mainboard
    • Thermal paste between the card and the body
  10. TCA PRC 152A Disassembly, Side connectors removal: adım 10, 2 resimden 1. TCA PRC 152A Disassembly, Side connectors removal: adım 10, 2 resimden 2.
    • Remove 2 screws
    • Phillips PH1
    • Carefully removing the connector
  11. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 11, 3 resimden 1. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 11, 3 resimden 2. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 11, 3 resimden 3.
    • Remove 2 screws
    • Phillips PH3
    • Remove the topcover, take care about short circuit
  12. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 12, 3 resimden 1. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 12, 3 resimden 2. TCA PRC 152A Disassembly, Batterybloc dissasembly: adım 12, 3 resimden 3.
    • Remove battery stick (18650 Panasonic)
    • Remove 2 screws
    • Phillips PH3
    • Take off the inner white retainer
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Tomazo_88
409 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 60
Her zaman: 4,278
