Ana içeriğe geç
TCA Yoke Calibration
    • If you have your Yoke plugged-in, then unplug it.
    • Set the switch at the back of the Yoke to PC position.
    • If you are using Xbox, you still need to set the switch to PC position.
    • Don't forget to switch it back to Xbox, once you have completed this guide.
    • Make sure that Roll and Pitch are at resting point.
    • Make sure the right mini-stick is at resting point.
    • Make sure that Throttles are in the middle
    • Throttles don't have to be in the exact middle.
  1. TCA Yoke Calibration, Press and hold the indicated buttons: adım 4, 1 resimden 1.
    • Press and hold the buttons highlighted in the image
    • Connect the Yoke to USB port while holding the buttons.
    • Once the Xbox button starts flashing, release the buttons.
  2. TCA Yoke Calibration, Press XBOX button: adım 6, 1 resimden 1.
    • Press on the Xbox button.
    • It should start flashing faster.
  3. TCA Yoke Calibration, Move the Yoke all the way to the right.: adım 7, 1 resimden 1.
    • Move the Yoke to the right, until you reach maximum.
    • Return the Yoke to Center.
    • For better results, move it smoothly, without forcing.
  4. TCA Yoke Calibration, Move the Yoke all the way to the left.: adım 8, 1 resimden 1.
    • Move the Yoke to the left, until you reach maximum.
  5. TCA Yoke Calibration, Push the Yoke forward: adım 9, 1 resimden 1.
    • Push the Yoke forward, until you reach maximum.
    • Make sure to not accidentally move yoke Left or Right.
  6. TCA Yoke Calibration, Pull the Yoke backwards: adım 10, 1 resimden 1.
    • Pull the Yoke towards yourself, until you reach maximum.
  7. TCA Yoke Calibration, Move the mini-stick to the right: adım 11, 1 resimden 1.
    • Move the mini-stick to the right, until you reach maximum.
    • Return the mini-stick to Center.
  8. TCA Yoke Calibration, Move the mini-stick to the left.: adım 12, 1 resimden 1.
    • Move the mini-stick to the left, until you reach maximum.
  9. TCA Yoke Calibration, Move the mini-stick up: adım 13, 1 resimden 1.
    • Move the mini-stick up, until you reach maximum.
  10. TCA Yoke Calibration, Move mini-stick down: adım 14, 1 resimden 1.
    • Move the mini-stick down, until you reach maximum.
  11. TCA Yoke Calibration, Move both Throttles down: adım 15, 1 resimden 1.
    • Move both throttles down, until you reach maximum.
  12. TCA Yoke Calibration, Move throttles up: adım 16, 1 resimden 1.
    • Move both throttles up, until you reach maximum.
  13. TCA Yoke Calibration, Press XBOX button: adım 17, 1 resimden 1.
    • Press Xbox button to finish the calibration.
    • Xbox button should stop flashing.
    • Make sure that Yoke, Throttles and mini-sticks have been returned to neutral positions.
Bitiş Çizgisi
Formica Fusca
2.595 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 81
Her zaman: 911
