Ana içeriğe geç
TCL Stylus Battery Replacement
Neye ihtiyacın var
    • Press and hold the Power button for 2 seconds.
    • Then, select "Power off".
    FixBot'a Sor
    Yorum Ekle
  1. TCL Stylus Battery Replacement, Remove back panel: adım 2, 3 resimden 1. TCL Stylus Battery Replacement, Remove back panel: adım 2, 3 resimden 2. TCL Stylus Battery Replacement, Remove back panel: adım 2, 3 resimden 3.
    • Insert a jimmy tool into the casing to create a gap.
    • Then, put a plastic pick in the gap and remove the jimmy tool.
    • Finally, lift up to remove the panel.
    FixBot'a Sor
    Yorum Ekle
  2. TCL Stylus Battery Replacement, Remove plastic shielding: adım 3, 2 resimden 1. TCL Stylus Battery Replacement, Remove plastic shielding: adım 3, 2 resimden 2.
    • Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
    • Then, grab a pick and put in in the slot show on picture 2.
    • You should then be able to lift the rest of it off.
    FixBot'a Sor
    Yorum Ekle
  3. TCL Stylus Battery Replacement, Unplug battery: adım 4, 2 resimden 1. TCL Stylus Battery Replacement, Unplug battery: adım 4, 2 resimden 2.
    • With your fingernail, lift up the battery connector.
    FixBot'a Sor
    Yorum Ekle
  4. TCL Stylus Battery Replacement, Unpeel tape: adım 5, 2 resimden 1. TCL Stylus Battery Replacement, Unpeel tape: adım 5, 2 resimden 2.
    • Unpeel the tape holding the battery.
    FixBot'a Sor
    Yorum Ekle
  5. TCL Stylus Battery Replacement, Remove battery: adım 6, 2 resimden 1. TCL Stylus Battery Replacement, Remove battery: adım 6, 2 resimden 2.
    • Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
    • NOTE: The pull tab may have resistance.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lee Hunt
1.288 İtibar
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
Lg syluis is a non removeable battery
katherine hicks - Yanıt Paylaş
It's just not easily removable. But every battery in every phone is removable if you know what you're doing. That's why the pictures explain. You come in here getting all worked up but your ignorance really shows. Obviously you don't have the intelligence to attempt this kind of repair, so go crochet me some mittens or something.
Cj Gabbard - Yanıt Paylaş
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
No removeable
Thanks for the information. At least you do not have to deal with heating the phone in order to loosen adhesive which is common with other phone models. Six steps to get to the battery is way easier than going through over 20 steps to do the same thing.
e s - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 55
Her zaman: 2,687
