Ana içeriğe geç
TDK Life on Record A26 Front Faceplate Replacement
Neye ihtiyacın var
  1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: adım 1, 2 resimden 1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: adım 1, 2 resimden 2.
    • Obtain the black plastic spudger to remove the faceplate.
    • Insert the pointed end of the tool inside one of the holes on the faceplate itself.
    • The corner is the best place to start.
    • The faceplate has many little holes so choose one that makes it easier for you.
  2. TDK Life on Record A26 Front Faceplate Replacement: adım 2, 3 resimden 1. TDK Life on Record A26 Front Faceplate Replacement: adım 2, 3 resimden 2. TDK Life on Record A26 Front Faceplate Replacement: adım 2, 3 resimden 3.
    • Gently start to lift until the faceplate starts to rise.
    • If you are having trouble getting the faceplate off, continue trying on the rest of the corners until fully removed.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Elise Howard
831 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 482
