Ana içeriğe geç
TDK Life on Record Trek 360 Air Vent Tube Replacement
Neye ihtiyacın var
  1. TDK Life on Record Trek 360 Air Vent Tube Replacement, Disassembling TDK Life on Record bottom panel: adım 1, 1 resimden 1.
    • Remove the four rubber feet of the device using a metal spudger.
  2. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 2, 2 resimden 1. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 2, 2 resimden 2.
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 3, 2 resimden 1. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 3, 2 resimden 2.
    • Pull the bottom cover of the device towards you.
  4. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 4, 2 resimden 1. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 4, 2 resimden 2.
    • Remove the four 13 mm Phillips #1 screws.
  5. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 5, 2 resimden 1. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 5, 2 resimden 2.
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 6, 1 resimden 1.
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
  7. TDK Life on Record Trek 360 Air Vent Tube Replacement, Air Vent Tube: adım 7, 1 resimden 1.
    • Remove the four 8 mm Phillips #1 screws.
  8. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 8, 3 resimden 1. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 8, 3 resimden 2. TDK Life on Record Trek 360 Air Vent Tube Replacement: adım 8, 3 resimden 3.
    • place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
    • Pull the plastic half circle towards you.
    • Put both of your hands inside the tube as shown and push away from you.
Sonuç
Helen Huynh
338 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G2
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where can I get a new motherboard?
american1gigolo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 715
