Ana içeriğe geç
TDK Life on Record Trek 360 Battery Replacement
Neye ihtiyacın var
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: adım 2, 3 resimden 1. TDK Life on Record Trek 360 Battery Replacement: adım 2, 3 resimden 2. TDK Life on Record Trek 360 Battery Replacement: adım 2, 3 resimden 3.
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: adım 3, 2 resimden 1. TDK Life on Record Trek 360 Battery Replacement: adım 3, 2 resimden 2.
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: adım 4, 3 resimden 1. TDK Life on Record Trek 360 Battery Replacement: adım 4, 3 resimden 2. TDK Life on Record Trek 360 Battery Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Helen Huynh
338 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G2
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Good guide, but what battery fits?
Niklas Aronsson - Yanıt
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 28
Her zaman: 3,699
