Ana içeriğe geç
TDK Life on Record Trek Max A34 Battery Replacement
Neye ihtiyacın var
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: adım 1, 2 resimden 1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: adım 1, 2 resimden 2.
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: adım 2, 2 resimden 1. TDK Life on Record Trek Max A34 Battery  Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: adım 3, 3 resimden 1. TDK Life on Record Trek Max A34 Battery  Replacement: adım 3, 3 resimden 2. TDK Life on Record Trek Max A34 Battery  Replacement: adım 3, 3 resimden 3.
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: adım 4, 2 resimden 1. TDK Life on Record Trek Max A34 Battery  Replacement: adım 4, 2 resimden 2.
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: adım 5, 1 resimden 1.
    • The battery is now separated from the device and may be replaced with a new battery.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kayla
315 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 19-3, Rauch Fall 2015 Texas Tech, Team 19-3, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S19G3
4 Üyeler
1 Kılavuz yazıldı
2 Yorum
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Yanıt
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 11,264
