Ana içeriğe geç
TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement
Neye ihtiyacın var
  1. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement, LCD Digitizer: adım 1, 1 resimden 1.
    • Twist both screws 180 degrees using a small flathead screwdriver. The arrows should be pointing to unlock. Slide the boot module down and out of the data collector.
  2. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 2, 1 resimden 1.
    • Remove both screws using a phillips head screwdriver. Pull the top cover up and out of the data collector.
  3. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 3, 1 resimden 1.
    • Remove any card that may be in the slots under the top cover you removed.
  4. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 4, 1 resimden 1.
    • Using a T6 torx driver, remove the 8 torx screws and then lift the back cover off. There is a rubber gasket between the front and back of the case. Make note of how it fits in for when you reassemble.
  5. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 5, 3 resimden 1. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 5, 3 resimden 2. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 5, 3 resimden 3.
    • Flip up the connector using a spudger and gently pull the ribbon cable out. This is the display assembly connector. Next we will gently pull the power cable up using a spudger or pry tool. The area marks by the yellow rectangle comes into play in the next step. This is where the keypad connects to the motherboard.
  6. TDS Trimble Spectra Precision Recon 400X LCD Digitizer Replacement: adım 6, 1 resimden 1.
    • Now we can remove the motherboard. Simply remove the 11 screws using a T6 torx driver. The motherboard must be lifted straight up. The keypad is connected from underneath the motherboard. It will unplug as you lift the board. That is what you want to happen
Sonuç
Karl
111 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 758
