Ana içeriğe geç
TI-36X Pro Battery Replacement
Neye ihtiyacın var
  1. TI-36X Pro Battery Replacement, Back Cover: adım 1, 2 resimden 1. TI-36X Pro Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the calculator's protective cover.
    • Place the calculator face down.
    FixBot'a Sor
    Yorum Ekle
  2. TI-36X Pro Battery Replacement: adım 2, 2 resimden 1. TI-36X Pro Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
    • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
    FixBot'a Sor
    Yorum Ekle
  3. TI-36X Pro Battery Replacement, Battery: adım 3, 2 resimden 1. TI-36X Pro Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
    • Remove the battery cover without disconnecting either end of the blue wire.
    • Use your finger to move the battery cover to the side.
    FixBot'a Sor
    Yorum Ekle
  4. TI-36X Pro Battery Replacement: adım 4, 1 resimden 1.
    • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
    • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Robert Sekerak
664 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-52, Amido Spring 2014 Cal Poly, Team 11-52, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G52
4 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Interesting that the cr2032 battery is not rechargeable, so is the solar panel real? Or does it bypass the battery and use the solar panel in lighted situations?
frogman896 - Yanıt Paylaş
The guide should specify that the CR2032 needs to be rechargeable. They are readily available at a popular online shopping website. I was skeptical that the solar was real too, because of the frosted plastic placed over it. Based on the pictures in this teardown, and another video showing a red LED in the solar circuit, I conclude that the solar charging circuit is real.
Jacob Ertel - Yanıt Paylaş
The manual doesn't specify a rechargeable battery. It just says a CR2032 Lithium battery. Unless all such batteries are rechargeable? I guess I'll find out since I just replaced the battery in mine and it's an Energizer CR2032, but it doesn't appear to say rechargeable anywhere on the packaging or the battery itself. I guess if it kills my calculator, it had a good run....
EDIT: The original battery that I took out of the calculator doesn't say rechargeable on it either.
Marc W - Yanıt Paylaş
good guide, I'd just like to add that in my case I needed to press the "Reset" button for my calculator to start up again
Greg B - Yanıt Paylaş
yeah but I have done that 3 times and now my calculator is officially announced dead....
Danielle Kennedy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 112
Her zaman: 37,131
