Ana içeriğe geç
TI-36X Pro Front Cover Replacement
Neye ihtiyacın var
  1. TI-36X Pro Front Cover Replacement, Back Cover: adım 1, 2 resimden 1. TI-36X Pro Front Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the calculator's protective cover.
    • Place the calculator face down.
  2. TI-36X Pro Front Cover Replacement: adım 2, 2 resimden 1. TI-36X Pro Front Cover Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
    • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
  3. TI-36X Pro Front Cover Replacement, Battery: adım 3, 2 resimden 1. TI-36X Pro Front Cover Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
    • Remove the battery cover without disconnecting either end of the blue wire.
    • Use your finger to move the battery cover to the side.
  4. TI-36X Pro Front Cover Replacement: adım 4, 1 resimden 1.
    • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
    • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
  5. TI-36X Pro Front Cover Replacement, Button: adım 5, 1 resimden 1.
    • After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
    • Do not disconnect any wires or you will need to solder them back on.
  6. TI-36X Pro Front Cover Replacement: adım 6, 1 resimden 1.
    • Next, use a Phillips #00 screwdriver to remove the two screws located on each side of the striped ribbon between the two green circuit boards.
  7. TI-36X Pro Front Cover Replacement: adım 7, 1 resimden 1.
    • Be careful not to scratch the gold lines on the circuit board since it may damage the circuit.
    • Carefully chisel off the 11 circular pieces that connect the lower circuit board to the calculator.
    • When reassembling the calculator, glue the lower circuit board back in place by dabbing glue into the holes that you chiseled.
  8. TI-36X Pro Front Cover Replacement: adım 8, 3 resimden 1. TI-36X Pro Front Cover Replacement: adım 8, 3 resimden 2. TI-36X Pro Front Cover Replacement: adım 8, 3 resimden 3.
    • When removing the parts from the calculator be careful not to break any wires or ribbons. The solar panel, screen, and lower circuit board should remain connected throughout this guide.
    • Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
    • Carefully pry the screen out of the calculator with a prying tool or spudger.
    • Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
  9. TI-36X Pro Front Cover Replacement: adım 9, 1 resimden 1.
    • Grab one of the top corners of the gray rubber button pad and peel it off of the buttons.
    • If you turn the calculator over, all of the buttons will fall out.
  10. TI-36X Pro Front Cover Replacement: adım 10, 2 resimden 1. TI-36X Pro Front Cover Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the button that needs replacement and lift it out of the calculator with tweezers.
    • If the buttons do fall out, use the second picture to put them back properly.
  11. TI-36X Pro Front Cover Replacement, Front Cover: adım 11, 1 resimden 1.
    • Empty the buttons into a bag or place them somewhere that they will not be lost.
    • Using a spudger, undo the 5 clips around the edge of the casing that connect the front cover to the calculator.
  12. TI-36X Pro Front Cover Replacement: adım 12, 1 resimden 1.
    • Pry the front cover off of the calculator with a prying tool from the bottom up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert Sekerak
664 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-52, Amido Spring 2014 Cal Poly, Team 11-52, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G52
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 1,988
