Ana içeriğe geç
TI-84 Plus Disassembly
Neye ihtiyacın var
  1. TI-84 Plus Disassembly, flip: adım 1, 2 resimden 1. TI-84 Plus Disassembly, flip: adım 1, 2 resimden 2.
    • Be sure the calculator is powered off before proceeding.
    • Take off the sliding cover, and flip your calculator to the back side.
  2. TI-84 Plus Disassembly, battery plate.: adım 2, 2 resimden 1. TI-84 Plus Disassembly, battery plate.: adım 2, 2 resimden 2.
    • Press down on the latch, then remove the battery cover.
  3. TI-84 Plus Disassembly, take out the batteries: adım 3, 2 resimden 1. TI-84 Plus Disassembly, take out the batteries: adım 3, 2 resimden 2.
    • Remove the batteries.
    • You can use the battery cover as a plate to keep the batteries.
  4. TI-84 Plus Disassembly, back up battery: adım 4, 3 resimden 1. TI-84 Plus Disassembly, back up battery: adım 4, 3 resimden 2. TI-84 Plus Disassembly, back up battery: adım 4, 3 resimden 3.
    • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
    • Use a Phillips #0 to remove the plate from the back up battery.
  5. TI-84 Plus Disassembly, backup battery: adım 5, 2 resimden 1. TI-84 Plus Disassembly, backup battery: adım 5, 2 resimden 2.
    • remove the backup battery with either a screwdriver or the spudger.
  6. TI-84 Plus Disassembly: adım 6, 1 resimden 1.
    • you can use a t6 or tr6 take out all six marked screws
  7. TI-84 Plus Disassembly, cracking the case: adım 7, 3 resimden 1. TI-84 Plus Disassembly, cracking the case: adım 7, 3 resimden 2. TI-84 Plus Disassembly, cracking the case: adım 7, 3 resimden 3.
    • Use a prying tool to get a pick into the side and then move it down until its open.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
martijn muntenaar
714 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 36
Son 30 gün: 160
Her zaman: 11,150
