Ana içeriğe geç
TI-84 Plus Silver Edition Backup Battery Replacement
Neye ihtiyacın var
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: adım 1, 3 resimden 1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: adım 1, 3 resimden 2. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: adım 1, 3 resimden 3.
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: adım 2, 1 resimden 1.
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: adım 3, 1 resimden 1.
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: adım 4, 1 resimden 1.
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: adım 5, 2 resimden 1. TI-84 Plus Silver Edition Backup Battery Replacement: adım 5, 2 resimden 2.
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Agustin
1.035 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-34, Amido Fall 2013 Cal Poly, Team 11-34, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G34
4 Üyeler
6 adet Kılavuz yazıldı
9Kılavuz Yorumları
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Yanıt
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Yanıt
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Yanıt
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 34
Son 30 gün: 203
Her zaman: 68,426
