Ana içeriğe geç
TI-84 Plus Silver Edition Battery Spring Replacement
Neye ihtiyacın var
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: adım 1, 2 resimden 1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: adım 1, 2 resimden 2.
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: adım 2, 2 resimden 1. TI-84 Plus Silver Edition Battery Spring Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: adım 3, 1 resimden 1.
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: adım 5, 2 resimden 1. TI-84 Plus Silver Edition Battery Spring Replacement: adım 5, 2 resimden 2.
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: adım 6, 1 resimden 1.
    • Test by replacing the battery that was taken out to check the connection.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi! So where can I get the spring part?
Aleyson B.Hunter - Yanıt
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 802
