Ana içeriğe geç
TM3D DWIN Added Screens
Neye ihtiyacın var
  1. TM3D DWIN Added Screens, Tools Menu: adım 1, 3 resimden 1. TM3D DWIN Added Screens, Tools Menu: adım 1, 3 resimden 2. TM3D DWIN Added Screens, Tools Menu: adım 1, 3 resimden 3.
    • Once your machine has booted up, from the Idle Screen, press Settings.
    • Press Tools
    • Initialize EEPROM will clear all soft data and restore the machine back to the last firmware settings installed. The screen may return to the idle screen.
    • Reset BLTouch is only valid if you have a BL Touch probe installed. This button will clear any current errors with the Probe. No movement or confirmation will occur.
    • Adjust Steps/mm will bring you to a new menu where you can calibrate each Axis' steps/mm. Pressing this will enter the Calibration screen for Steps/mm.
    • PID Tuning will bring you to a new menu where you can calibrate thermal settings. Pressing this will enter the Calibration screen for PID Tuning.
    What is exactly the "soft data"? If I run a pid tune, or I set the offsets and I store them to the mainboard, are they still "soft data" and pressing the "initialize EEPROM" will erase them?
    So what does "last firmware settings" really mean? If I ran a pid tune using my old firmware, and I stored them. Then I upgraded to the new firmware, are these settings now the "last firmware settings"? Or are they still regarded as "soft settings" and will not count?
    I am asking because basically if it erases these stored settings, there is no point of reference anymore. We need to know exactly what are the "last firmware settings" in this context before pressing this button.
    kornelis bijker - Yanıt
    In the pid tuning screen, you have auto and manual. I do not see anywhere how many cycles it takes before giving you the return readout? Also, immediately after I push the auto pid tune, the screen says pid tune finished! But it is still cycling through the process of heating and cooling. It also tells you different pid figures a few times, so how do I know exactly when it is really finished?
    Then, when it is really finished, the new numbers show up in the manual section. If press the "store settings" button, is it storing these figures? So, if I run a pid tune with octoprint, or with pronterface, and I have my new pid figures, I could theoretically fill them in here and store them? But other then that there is no real manual part to this pid tuning.
    Bit unclear as to why there is this manual part, if you have figures for pid from some other tuning session, you can also easily enter them into the g-code terminal and save them. Unless I am missing something, I don't see the point of this manual pid tuning.
  2. TM3D DWIN Added Screens, Calibration Screens: adım 2, 2 resimden 1. TM3D DWIN Added Screens, Calibration Screens: adım 2, 2 resimden 2.
    • These values are set for your machine and normally do not need modified. Edit at your own risk! However, if you feel you make a mistake, you can Initialize EEPROM from the Tools menu.
    • Calibration
    • The white boxes will all be populated with your printer's settings.
    • Probe Offset can be changed if you change the probe to nozzle relationship.
    • Steps/mm can be changed to fine tune your machine or add an aftermarket extruder. A popular bench test is a 20mm cube.
    • Calibration-PID Tuning>PID Automatic Tuning will initiate an automatic PID calibration. Enter a temperature 10 degrees over your printing temperature and press Start.
    • Calibration-PID Tuning>PID Manual Tuning will display the current saved values and allow manual adjustment.
    • After desired changes are made, press Store Settings
  3. TM3D DWIN Added Screens, Error Screens: adım 3, 3 resimden 1. TM3D DWIN Added Screens, Error Screens: adım 3, 3 resimden 2. TM3D DWIN Added Screens, Error Screens: adım 3, 3 resimden 3.
    • These Error screens are hard faults and a power cycle will be necessary to clear them.
    • Thermistor Error! This is usually a wiring or component issue.
    • If reading is 0 or lower, you have an open circuit. This means 1 or both wires are not connected to maintain reasonably resistance. It could be from a broken wire or simply, an unplugged connection.
    • Heating Failed! This is sometimes a wiring or component issue.
    • This usually means a wire to the heated bed or nozzle has been damaged or unplugged but not always. It could be that you have the target temperature set to high for the available power and it is taking too long in your current environment.
    • MACHINE FAULT This is sometimes a wiring issue.
    • If an end stop (limit switch) is unplugged or isn't triggered during homing
    • Verify that all limit switches work (Serial Terminal using M119 command) and are contacted by the machine by hand.
    I've got a Creality CR-10S Pro V2. I would like to flash the firmware for the display screen and I can not find where that would be at. can or will someone please help me.
    Paul LaFrance - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tiny Machines 3D
3.019 İtibar
14 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
10Kılavuz Yorumları
This is so hot mess, looking at Ender 5 Plus firmware and screen update…..documents are all out dated and files are not correct just a hot mess and wasted 2 hours try to figure your crap out.
Chris C - Yanıt
What are you referring to? If you’re having issues with a firmware update, the best way to contact us is email - support@tinymachines3d.com.
https://docs.google.com/document/d/1lkhv... is where we have the latest files.
Tiny Machines 3D -
Hi
I have installed latest version of UI for CR10s Pro and Marlen 2.0.x. What is extruder value for, not defined above?
I want to know how to modify extrusion rate steps/mm thank you?
Johan Dekker - Yanıt
Can the screen firmware be flashed on any Ender 5 Plus? And it will just work? or does the board need firmware updates too? I’m running the Creatlity silent board
tom jones - Yanıt
Is there a better way for you guys to post these firmware as it is very confusing the way it is at the moment. Even if you have a added file that explains what things in your filenames mean. For eg: E5PUBLSlntDZ_MC_DW7.4.5.hex.zip what does this all mean. Why not use E5PL at the start as the E5P just made me think it was for the 5 Pro. what is SintDZ-MC for. I am guessing silent board but no ide what the DZ or MC is for. I am not trying to be negative as I really appreciate the work you put into making these firmware updates, just hoping to get it a little easier for a first timer like me to understand what things mean. Thanks again for everything you have done.
J SHARPE-LAUDNANI - Yanıt
Ender 5 Pro doesn't get a special name because there is no difference between that machine and standard Ender 5 with regards to firmware.
check the link
https://github.com/InsanityAutomation/Ma...
Tiny Machines 3D is a primary sponsor in the development of our firmware, but we are not the author. Insanity Automation develops and maintains firmware for a few vendors, including Tiny Machines 3D.
The latest supported release for customers is https://github.com/InsanityAutomation/Ma... Anything newer is not thoroughly tested by Tiny Machines 3D. The process for reporting bugs, issues or concerns for any firmware outside our support is outlined below.
Insanity Automation, the firmware author, has launched a discord server in order to help manage issues and support. There is a dedicated channel, accessible only to supporters, where they can receive priority support or customization assistance as well.
Insanity Automation Discord - https://discord.gg/TKmJ85PyG4
Tiny Machines 3D -
How old is the latest files? Hex and screen?
Andre “OBCGenji” - Yanıt
I have a CR 10 S pro V2 touchscreen, all of a sudden switch to Chinese and will not work
Jamesl187 - Yanıt
Can you explain how the time on the printing page works crealitys own just said the time I’d been printing for, the tiny machines firmware shows 84 on one side of the screen and 5: 23 on the other I’ve been printing for 6 hours
Matthew Harrington - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 96
Her zaman: 12,535
