Ana içeriğe geç
TOSHIBA Satellite E45W-C4200X Battery Replacement
Neye ihtiyacın var
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: adım 1, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 2, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 2, 2 resimden 2.
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 3, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 3, 2 resimden 2.
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 4, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 4, 2 resimden 2.
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 5, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 5, 2 resimden 2.
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 2,110
