Ana içeriğe geç
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
Neye ihtiyacın var
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 2, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 3, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 4, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 5, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 6, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 6, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: adım 6, 3 resimden 3.
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
Sonuç
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 361
