Ana içeriğe geç
TOSHIBA Satellite E45W-C4200X Motherboard Replacement
Neye ihtiyacın var
  1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Cooling Fan: adım 1, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 2, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 2, 2 resimden 2.
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 3, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 4, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 5, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 6, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 6, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 6, 3 resimden 3.
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
  7. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Unplug the connection to the battery.
    • Mark sure you are using the anti-static wrist strap for the duration of this replacement.
  8. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 8, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 8, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove all remaining external wire harnesses from the circuit board.
    • It is recommended that you use labels or take pictures of the wires you remove to assist in the re-connection.
  9. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
    • Remove the bracket.
  10. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 10, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 10, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
    • Remove the black plastic cover.
  11. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 11, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
    • Carefully remove the motherboard from the device.
Sonuç
Bir Yorum
Could you help me to know the values for this piece? My motherboard has burned it, and I could not find the schematic; I guess it is an inductor. But I'm just learning about this. I hope that you can help me.
Regards.
https://ibb.co/TKCGPpF
Developer Paridin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 930
