Ana içeriğe geç
TOSHIBA Satellite E45W-C4200X RAM Replacement
Neye ihtiyacın var
  1. TOSHIBA Satellite E45W-C4200X RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the ten 1 mm screws on the back panel.
  2. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 2, 2 resimden 1. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to separate the back panel from the rest of the computer.
    • Be careful and do not to crack the panel.
  3. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 3, 2 resimden 1. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 3, 2 resimden 2.
    • Remove the grey film covering the RAM located on the left side of the computer.
  4. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 4, 3 resimden 1. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 4, 3 resimden 2. TOSHIBA Satellite E45W-C4200X RAM Replacement: adım 4, 3 resimden 3.
    • Apply pressure on the inside of both brackets until the RAM chips are released.
    • Repeat this step for RAM Slot B.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 552
