Ana içeriğe geç
TOSHIBA Satellite E45W-C4200X Screen Replacement
Neye ihtiyacın var
  1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: adım 1, 2 resimden 1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Using a plastic opening tool, remove the plastic bar underneath the screen.
    • Use caution when removing the plastic bar to prevent cracking.
  2. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #1 screwdriver and remove the four screws at the bottom of the screen.
    • Be sure to store the screws in a safe place to prevent losing them.
  3. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 3, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 3, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 3, 3 resimden 3.
    • Use the blue plastic opening tool to start separating the plastic cover from the screen.
    • Once started, use the Jimmy to run along the edges to complete the separation.
    • Be sure to go very slow to avoid cracking the glass further and possibly cutting yourself.
    • The camera is still connecting the protective cover to the laptop; we recommend setting it on top of the keyboard.
  4. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 4, 1 resimden 1.
    • Remove the remaining screws that hold the screen in place using the Phillips #1 screwdriver.
    • Carefully lift out the screen and fold on its face.
    • The screen is still attached, do not pull away from the laptop.
  5. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 5, 3 resimden 1. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 5, 3 resimden 2. TOSHIBA Satellite E45W-C4200X Screen Replacement: adım 5, 3 resimden 3.
    • Disconnect the screen from the small circuit board.
    • Gently disconnect with even pressure on both sides to prevent damage.
    • The old screen has now been completely removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 1,909
