Giriş
With this guide, you will be able to learn how to replace your Trackpad on your Toshiba Satellite E45W-C4200X.
The trackpad is vital tool for controlling your curser on your computer.
Before using this guide, make sure to review the troubleshooting page to ensure theTrackpad will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Neye ihtiyacın var
Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
Bir başkası bu kılavuzu tamamladı.
