Ana içeriğe geç
TRS-80 Color Computer Fuse Replacement
Neye ihtiyacın var
  1. TRS-80 Color Computer Fuse Replacement, Outside Casing: adım 1, 1 resimden 1.
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Fuse Replacement: adım 2, 2 resimden 1. TRS-80 Color Computer Fuse Replacement: adım 2, 2 resimden 2.
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Fuse Replacement, Keyboard: adım 3, 2 resimden 1. TRS-80 Color Computer Fuse Replacement, Keyboard: adım 3, 2 resimden 2.
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Fuse Replacement, Motherboard: adım 4, 3 resimden 1. TRS-80 Color Computer Fuse Replacement, Motherboard: adım 4, 3 resimden 2. TRS-80 Color Computer Fuse Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Fuse Replacement: adım 5, 3 resimden 1. TRS-80 Color Computer Fuse Replacement: adım 5, 3 resimden 2. TRS-80 Color Computer Fuse Replacement: adım 5, 3 resimden 3.
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Fuse Replacement, Fuse: adım 6, 2 resimden 1. TRS-80 Color Computer Fuse Replacement, Fuse: adım 6, 2 resimden 2.
    • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  7. TRS-80 Color Computer Fuse Replacement: adım 7, 3 resimden 1. TRS-80 Color Computer Fuse Replacement: adım 7, 3 resimden 2. TRS-80 Color Computer Fuse Replacement: adım 7, 3 resimden 3.
    • Remove the power cable jumpers from the power supply.
  8. TRS-80 Color Computer Fuse Replacement: adım 8, 1 resimden 1.
    • Gently peel back the protective film on the top of the transformer.
  9. TRS-80 Color Computer Fuse Replacement: adım 9, 3 resimden 1. TRS-80 Color Computer Fuse Replacement: adım 9, 3 resimden 2. TRS-80 Color Computer Fuse Replacement: adım 9, 3 resimden 3.
    • Locate the two points the fuse is soldered into the circuit board.
    • Using a soldering iron and soldering wick, desolder and remove the fuse.
    • Place the new fuse into the location of the old one, and solder it in place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Christopher Paige
549 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G24
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,791
