Ana içeriğe geç
Tagital T10 Camera Replacement
Neye ihtiyacın var
    1. Tagital T10 Camera Replacement, Camera: adım 1, 1 resimden 1.
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Tagital T10 Camera Replacement: adım 2, 1 resimden 1.
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      FixBot'a Sor
      Yorum Ekle
    3. Tagital T10 Camera Replacement: adım 3, 1 resimden 1.
      • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
      FixBot'a Sor
      Yorum Ekle
    4. Tagital T10 Camera Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
      FixBot'a Sor
      Yorum Ekle
    5. Tagital T10 Camera Replacement: adım 5, 1 resimden 1.
      • Locate the small ZIF connector that connects to the cameras.
      • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
      • The camera can now be lifted from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Destin Dawsy
328 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G5
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 533
