Giriş
The front and back cameras in this tablet are connected as one piece. Both cameras have to be replaced if either one is broken.
Neye ihtiyacın var
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Use a spudger to hold the cameras in place.
Gently pull the black tape away using your finger.
Bir başkası bu kılavuzu tamamladı.
