Giriş
This guide will show you how to replace the screen of a Tagital T9X.
Neye ihtiyacın var
With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
2 farklı kişi bu kılavuzu tamamladı.
