Ana içeriğe geç
Tagital T9X Speaker Replacement
Neye ihtiyacın var
  1. Tagital T9X Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Speaker Replacement: adım 2, 1 resimden 1.
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Detach speaker wires from motherboard.
    • The wires are fragile and may break off while handling them.
  4. Tagital T9X Speaker Replacement: adım 4, 1 resimden 1.
    • Use the plastic spudger to remove speaker from the back panel.
Sonuç
1Rehber Yorum
Hi. I need a replacement speaker for my tagital t9x. What part number should I look up?
Jerry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 139
