Giriş
Removing a white Unibody MacBook disk drive and RAM.
Neye ihtiyacın var
Then Unplug the battery using a ESD Safe prying tool.
After removing the screws and plastic cover piece, remove the hard drive then unplug from Logic Board.
Locate the RAM Directly above the Hard Drive. Gently push the two snaps away from the RAM cards and gently pull the ram out. You Will do this step again to remove the Second card beneath the first.
12 farklı kişi bu kılavuzu tamamladı.
