Ana içeriğe geç
Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement
Neye ihtiyacın var
  1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: adım 1, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: adım 1, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement, 1/10 Scale Brushed Motor: adım 1, 3 resimden 3.
    • Remove the four screws with a Phillips #00 screwdriver.
  2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 2, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 2, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 2, 3 resimden 3.
    • Slowly remove the body, lifting it upward from the chassis.
    • Hold the front and back of the body with both hands when removing it.
    • Lift the body past the antenna to avoid damaging it.
  3. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 3, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 3, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 3, 3 resimden 3.
    • Attach your box wrench with the 7mm side facing into the rim onto the hex-nut.
    • Twist the box wrench left (counter-clockwise) and unscrew the hex-nut until it comes off.
    • Hold the tire in place to prevent the tire from spinning with your box wrench.
  4. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 4, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 4, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 4, 3 resimden 3.
    • Grab both the yellow and black wire as well as the green and orange wire and pull them apart.
    • The wire connectors may be difficult to remove. Do not hesitate to use more force to remove them from each other, if necessary.
    • It does not matter which wires you disconnect or connect first.
  5. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 5, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 5, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 5, 3 resimden 3.
    • Loosen the first screw on the motor cover using a Phillips #00 screwdriver.
    • Loosen the bottom screw next, and you will feel the motor come loose.
    • The bottom screw has more leverage on the motor, so reverse these steps when re-assembling.
    • The motor cover is black, mine is spray-painted green.
  6. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 6, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 6, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 6, 3 resimden 3.
    • Finish loosening the long screws with your Phillips #00 screwdriver.
    • Slowly pull the motor cover away from the gearbox, with the two long Phillips screws still inside the motor cover.
    • Pull the motor away from the gearbox.
    • Do not force the motor out. Let it slide into your hand if necessary to avoid damaging components or gears inside the gearbox.
  7. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 7, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 7, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 7, 3 resimden 3.
    • Gently slide your 540 motor into the gearbox. Make sure it is correctly inline with the pinion (the middle gear segment).
    • Slide the motor cover, then the long screws into the left side of the gearbox to align the motor with the gearbox.
    • Make sure all the holes to the motor cover, motor, and gearbox line up with the two long screws that hold the motor cover on.
  8. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 8, 3 resimden 1. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 8, 3 resimden 2. Tamiya 1/10 Scale Grasshopper Brushed Motor Replacement: adım 8, 3 resimden 3.
    • Tighten the bottom screw with your Phillips #00 screwdriver.
    • Lay the buggy down and tighten the top screw next, to help ensure the motor is properly in place.
    • If you tighten the motor to the gearbox, but your pinion misaligned with the main gear, your motor will NOT move the car, which may cause damage to the motor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Traccitto
157 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team B-8, Allen Fall 2022 York University, Team B-8, Allen Fall 2022 üyesi
YORK-ALLEN-F22SBG8
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 444
