Ana içeriğe geç
Taranis X9D & X9D Plus Hall Effect Gimbals Replacement
Neye ihtiyacın var
  1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: adım 1, 3 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: adım 1, 3 resimden 2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: adım 1, 3 resimden 3.
    • Place the device so that the bottom is facing up.
    • Slide the battery compartment open.
    • Pull the battery by the plastic connector (not the wires) and shim left and right until the cable disconnects.
  2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 2, 1 resimden 1.
    • Remove the eight screws holding the gimbals to the front of the case using a 2.5 mm Hex key.
    • Push all switches forward or away from you (this will be important for reassembly).
  3. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 3, 3 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 3, 3 resimden 2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 3, 3 resimden 3.
    • Remove six screws from the back of the device using a Phillips #0 screwdriver.
    • Ensure the switches are in the position from the previous step, as they are not held in place and can reverse direction.
    • Gently pull the back up and open the radio in the form of a book, with the battery compartment being the spine.
    • Lay the controller on its front so that as the last screw is removed, the two halves don't fall apart.
  4. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 4, 2 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 4, 2 resimden 2.
    • Detach a total of six connectors (three per gimbal).
    • Pull the gimbals out from the radio frame.
  5. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 5, 2 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 5, 2 resimden 2.
    • New gimbals come in left and right boxes, respectively, so as not to mix them up, as well as identical connections for a drop-in replacement.
    • New gimbals will include new hex bolts for the front, as the stock ones will not fit.
    • When dropping the new gimbals into place, the harnesses will face downwards on their respective side.
    • Do not press on the cables. Push down on the connectors with your thumbs.
  6. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 6, 1 resimden 1.
    • Reattach the eight screws back onto the frame of the controller using a 2.5 mm Hex key.
  7. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 7, 2 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 7, 2 resimden 2.
    • Close the radio back up like a book, and verify the switches are in the same position.
    • Reattach the six screws to the back panel using a Phillips #0 screwdriver.
  8. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 8, 3 resimden 1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 8, 3 resimden 2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: adım 8, 3 resimden 3.
    • Reinsert the battery and the battery door.
    • Turn on the radio and verify the correct installation from the on-screen information (check the switch positions with the on-screen display).
    • New gimbals may require recalibration depending on the settings of your stock gimbals.
Bitiş Çizgisi
Saad Irfan
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 126
