Ana içeriğe geç
Tatung TAC-6G Heating Element Replacement
Neye ihtiyacın var
    1. Tatung TAC-6G Heating Element Replacement, Heating Element: adım 1, 1 resimden 1.
      • Lift the lid and bowl from top of the device
      • Be sure device is not plugged in before beginning replacement of heating element
      FixBot'a Sor
      Yorum Ekle
    2. Tatung TAC-6G Heating Element Replacement: adım 2, 1 resimden 1.
      • Turn the bowl upside down so that the three legs point upwards
      FixBot'a Sor
      Yorum Ekle
    3. Tatung TAC-6G Heating Element Replacement: adım 3, 2 resimden 1. Tatung TAC-6G Heating Element Replacement: adım 3, 2 resimden 2.
      • Remove the one 7 mm Phillips screw from the side of the brass panel.
      FixBot'a Sor
      Yorum Ekle
    4. Tatung TAC-6G Heating Element Replacement: adım 4, 2 resimden 1. Tatung TAC-6G Heating Element Replacement: adım 4, 2 resimden 2.
      • Remove the 6mm Phillips screw that holds the stainless plate.
      FixBot'a Sor
      Yorum Ekle
    5. Tatung TAC-6G Heating Element Replacement: adım 5, 3 resimden 1. Tatung TAC-6G Heating Element Replacement: adım 5, 3 resimden 2. Tatung TAC-6G Heating Element Replacement: adım 5, 3 resimden 3.
      • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
      FixBot'a Sor
      Yorum Ekle
    6. Tatung TAC-6G Heating Element Replacement: adım 6, 1 resimden 1.
      • Using your hands, remove the heating plate that is on top of heating element.
      FixBot'a Sor
      Yorum Ekle
    7. Tatung TAC-6G Heating Element Replacement: adım 7, 1 resimden 1.
      • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
      FixBot'a Sor
      Yorum Ekle
    8. Tatung TAC-6G Heating Element Replacement: adım 8, 1 resimden 1.
      • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
      FixBot'a Sor
      Yorum Ekle
    9. Tatung TAC-6G Heating Element Replacement: adım 9, 1 resimden 1.
      • Using, your hands, take out the heating element and replace it with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
where can I buy this heating element? Thanks.
dchang168 - Yanıt Paylaş
Tze Moh Yeo - Yanıt Paylaş
where to buy parts is the problem!!
William Co - Yanıt Paylaş
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 57
Her zaman: 5,492
