Ana içeriğe geç
Tatung TAC-6G Light Element Replacement
Neye ihtiyacın var
  1. Tatung TAC-6G Light Element Replacement, Light Element: adım 1, 1 resimden 1.
    • Start with the device standing upright.
  2. Tatung TAC-6G Light Element Replacement: adım 2, 1 resimden 1.
    • Remove the 11mm Phillips screw from below the power component panel.
  3. Tatung TAC-6G Light Element Replacement: adım 3, 1 resimden 1.
    • Pull the panel away from the rice cooker.
    • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
  4. Tatung TAC-6G Light Element Replacement: adım 4, 1 resimden 1.
    • Pull the light plate from the power component panel.
  5. Tatung TAC-6G Light Element Replacement: adım 5, 1 resimden 1.
    • Flip the rice cooker device upside down.
  6. Tatung TAC-6G Light Element Replacement: adım 6, 2 resimden 1. Tatung TAC-6G Light Element Replacement: adım 6, 2 resimden 2.
    • Remove the one 7mm Phillips screw from the side of the brass panel
    • Lift the brass plate off of the device and set it aside.
  7. Tatung TAC-6G Light Element Replacement: adım 7, 1 resimden 1.
    • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
  8. Tatung TAC-6G Light Element Replacement: adım 8, 1 resimden 1.
    • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
  9. Tatung TAC-6G Light Element Replacement: adım 9, 1 resimden 1.
    • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
  10. Tatung TAC-6G Light Element Replacement: adım 10, 1 resimden 1.
    • Using your hand, pull out the light plate with the maroon red and black wires.
  11. Tatung TAC-6G Light Element Replacement: adım 11, 1 resimden 1.
    • Replace the light plate dashboard.
Sonuç
Bir Yorum
Reverse the steps for reassembly.
Tom Anderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 613
