Giriş
This device's power cord may break, so being able to easily replace it is important. This guide will teach you how to replace the rice cooker's power cord.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks! Ours wore out at the crimped part where the cable exits the rice cooker. After opening it up, we cut the cable ~6" from the loose end (not the plug end!), separated the two wire bundles, stripped part of the black plastic off (~1/5") slid the fiberglass sheaths over to the new bundles and attached w/o the circle metal ends by screwing it into the original place.
