Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn device upside-down so that the three legs point upwards.
Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
Lift the brass plate from the device and set it aside.
Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
Using your hands, from the inside of the device, push the black plastic wire holder to release cords.
Pull the power cord through the hole, isolating the power cord from the device.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks! Ours wore out at the crimped part where the cable exits the rice cooker. After opening it up, we cut the cable ~6" from the loose end (not the plug end!), separated the two wire bundles, stripped part of the black plastic off (~1/5") slid the fiberglass sheaths over to the new bundles and attached w/o the circle metal ends by screwing it into the original place.
