Ana içeriğe geç
Tea Kettle Switch Replacement
Neye ihtiyacın var
  1. Tea Kettle Switch Replacement, Switch: adım 1, 3 resimden 1. Tea Kettle Switch Replacement, Switch: adım 1, 3 resimden 2. Tea Kettle Switch Replacement, Switch: adım 1, 3 resimden 3.
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: adım 2, 2 resimden 1. Tea Kettle Switch Replacement: adım 2, 2 resimden 2.
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: adım 3, 1 resimden 1.
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: adım 4, 1 resimden 1.
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: adım 5, 1 resimden 1.
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: adım 6, 1 resimden 1.
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
3 Yorum
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Yanıt
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 147
Her zaman: 24,984
