Giriş
If you have identified that your record player needs to have its motor replaced, this guide will show you how to safely do so. The motor is what controls the speed the record plays at, and may wear down or completely fail over time and with use. Replacement is easy if these steps are followed. Note that it is first important to complete the Disassembly Guide.
Neye ihtiyacın var
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
