Ana içeriğe geç
Teac DC-D2831 Drive Belt replacement
Neye ihtiyacın var
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: adım 1, 2 resimden 1. Teac DC-D2831 Drive Belt replacement, Drive Belt: adım 1, 2 resimden 2.
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: adım 2, 1 resimden 1.
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: adım 3, 3 resimden 1. Teac DC-D2831 Drive Belt replacement: adım 3, 3 resimden 2. Teac DC-D2831 Drive Belt replacement: adım 3, 3 resimden 3.
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: adım 4, 1 resimden 1.
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
Sonuç
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Charles Lockner
115 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G61
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 3,588
