Ana içeriğe geç
Teddy Bear Nose Replacement
Neye ihtiyacın var
  1. Teddy Bear Nose Replacement, Nose: adım 1, 2 resimden 1. Teddy Bear Nose Replacement, Nose: adım 1, 2 resimden 2.
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: adım 2, 2 resimden 1. Teddy Bear Nose Replacement: adım 2, 2 resimden 2.
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: adım 3, 1 resimden 1.
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: adım 4, 2 resimden 1. Teddy Bear Nose Replacement: adım 4, 2 resimden 2.
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: adım 5, 1 resimden 1.
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: adım 6, 1 resimden 1.
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: adım 7, 1 resimden 1.
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: adım 8, 1 resimden 1.
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: adım 9, 1 resimden 1.
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: adım 10, 3 resimden 1. Teddy Bear Nose Replacement: adım 10, 3 resimden 2. Teddy Bear Nose Replacement: adım 10, 3 resimden 3.
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: adım 11, 2 resimden 1. Teddy Bear Nose Replacement: adım 11, 2 resimden 2.
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Bitiş Çizgisi
Nazib Khan
193 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 98
Her zaman: 3,825
