Ana içeriğe geç
Teenage Engineering OP-1 DSP Board Replacement
Neye ihtiyacın var
  1. Teenage Engineering OP-1 DSP Board Replacement, key removal: adım 1, 3 resimden 1. Teenage Engineering OP-1 DSP Board Replacement, key removal: adım 1, 3 resimden 2. Teenage Engineering OP-1 DSP Board Replacement, key removal: adım 1, 3 resimden 3.
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 DSP Board Replacement, removing scissors mechanisms: adım 2, 2 resimden 1. Teenage Engineering OP-1 DSP Board Replacement, removing scissors mechanisms: adım 2, 2 resimden 2.
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 DSP Board Replacement, unscrew keyboard: adım 3, 3 resimden 1. Teenage Engineering OP-1 DSP Board Replacement, unscrew keyboard: adım 3, 3 resimden 2. Teenage Engineering OP-1 DSP Board Replacement, unscrew keyboard: adım 3, 3 resimden 3.
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 DSP Board Replacement, unplug and remove keyboard: adım 4, 1 resimden 1.
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
  5. Teenage Engineering OP-1 DSP Board Replacement, remove display: adım 5, 3 resimden 1. Teenage Engineering OP-1 DSP Board Replacement, remove display: adım 5, 3 resimden 2. Teenage Engineering OP-1 DSP Board Replacement, remove display: adım 5, 3 resimden 3.
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
  6. Teenage Engineering OP-1 DSP Board Replacement, DSP Board: adım 6, 2 resimden 1. Teenage Engineering OP-1 DSP Board Replacement, DSP Board: adım 6, 2 resimden 2.
    • Disconnect the battery connector from the DSP board.
    • Unscrew the two Phillips #00 screws holding the board down.
  7. Teenage Engineering OP-1 DSP Board Replacement: adım 7, 2 resimden 1. Teenage Engineering OP-1 DSP Board Replacement: adım 7, 2 resimden 2.
    • Now you can carefully lift the DSP board to access the flex cable connector underneath.
    • Disconnect the flex cable by using a spudger and remove the DSP board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.104 İtibar
189 adet Kılavuz yazıldı
Ekip
13 Yorum
Can you advise me where I can order DSP board?
Ju-seok Jang - Yanıt
Hi Ju-seok Jang, unfortunately we don’t sell this spare part. You might be able to reach Teenage Engineering directly and get an answer from them where to purchase that part.
Tobias Isakeit -
I reached out to teenage engineering a month ago about ordering a replacement but they still haven’t responded. Pretty unacceptable seeing as they have a “do it yourself!” ethos for their $1,000 device…
Ben Fischer - Yanıt
Hi! Did you find a solution? I have the same issue. Thanks!
Juan Rodríguez Berbín -
My OP-1 wouldn’t go into boot mode, and TE told me it was probably the DSP board, and they would look at it for a fee since it was out of warranty. Now I can’t find the DSP board anywhere to do this repair. I then found out this was a common problem, a manufacturing defect. I wonder if there are enough people with these problems the EU 2 year warranty rule can be invoked, or a class-action suit of some sort. TE has basically left those who have these problems without an option to repair the TE manufacturing defect.
Rob
Robert Herman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 95
Her zaman: 12,765
