Ana içeriğe geç
Teenage Engineering OP-Z Back Cover Replacement
  1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Back Cover Replacement: adım 2, 2 resimden 1. Teenage Engineering OP-Z Back Cover Replacement: adım 2, 2 resimden 2.
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Back Cover Replacement: adım 3, 1 resimden 1.
    • Remove the bottom plate including the rubber feet.
Sonuç
Tobias Isakeit
124.495 İtibar
189 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
and uhm where to order the backplate? :/
boombipbass - Yanıt
Same question
Grant Dacklin -
Do you not sell the plate anymore?
Jason - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 1,765
