Giriş
Use this guide to replace the highway flex cable in the OP-Z. The flex cable includes the USB-C port, and the line-out / headphone jack.
Neye ihtiyacın var
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
Use your finger or a spudger to push up on the small tab on the bottom of the module.
Lift the module up and out of its recess bottom first.
Use a spudger to disconnect the highway flex cable from the DSP board.
2 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
It worked! Sort of. I bought a highway flex cable replacement and a new battery hoping it would solve an issue. The good news is I was able to replace it, and it’s function as before I replaced the flex cable. The only challenge really was that the audio cable plug in the new flex cable assemble was slightly bigger than the one I removed. I really had to force it down. During reassemble it was important to start left to right too - and it was easier to plug that last cable before installing the audio and USB C sockets. The issue I was trying to solve: My OP-Z will only power on when plugged in. I bought the OP Z used, and it worked fine for a while. But for reasons I can’t explain it stopped working with battery power alone. I tried all the solutions I found online including resetting the battery, firmware, etc. I’m just sharing this in case someone else has the same issue. Other than that, the new flex cable works just like the one it replaced, and I have an extra one now! Thank you!!!
