Giriş
Use this guide to remove the midframe in an OP-Z.
Neye ihtiyacın var
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
Use your finger or a spudger to push up on the small tab on the bottom of the module.
Lift the module up and out of its recess bottom first.
Neredeyse bitti!
Sonuç
